code 1 !!
Discussion in 'General Tech and Maintenance' started by dranomcfly, Sep 13, 2005.
  1. dranomcfly
    dranomcfly Junior Member
    Hey there,
    I have a b-17 in a Can. cx (base model) hatch back. Runs with gsr jdm headers and straight pipe. I have NO O2 sensors on the car and the wires are nowhere to be found. The ecu is throwing a code1 whenever I slow down without downshifting.
    I was wondering if code 1 is dangerous for the engine?
    Which wires are for the O2 sensor on a obd I engine harness?
    Any of you ever work with an O2 simulator?
    I know this is not very environment friendly but I really don't have 200$ for a sensor.
    Thanks
  2. drpenguin
    drpenguin Senior Member
    Salem, Or
    200 for a sensor? shit man i will send you a stock honda 4 wire obd1 O2 sesor for $15! as for where it goes i have mine speccially wired to the ecu in the rex. just wire it straight to where it goes on the ecu!
