code 14? or is it 15? code help 94 ex !!
NEWBIEDAN
first off, if this question is in the wrong section im very sorry.
second off, im not a guy who asks random ass questions without searching in the forums for 3 hours trying to find a similar question to get the answer...
that being said, here we go
1994 civic ex. d16z6
check engine light on
pulled codes = 1 long and 4 short, then one really fuckin fast short one. like maybe 1/8 the duration of a normal short code.
i know how long the long one is
i know how long the short ones are also...
but what the hell is the super fast 1/8 length blink, is it possibly just telling you thats the end?? anyone else have this happen?
so i guess my question is, is my code a 14 or does the super fast flash at the end count as a short flash making a 15???
14 would make sense... it kinda idles a little rough and a little erratic.
thanks alot in advance for any help you an give me!!!
Code 15 is ignition, so if it's idling erratically I'd say it's 14.
Do the rpm's jump around when you're driving? If not, it's definitely a 14.
thats what im hoping.. and thats what i figured. but has anyone seen this last flash? is it normal??? if there was a code 15 for ignition wouldnt the car not run?
thanks again for the help guys
alright, so correct me if i am wrong... shouldn't my 94 ex d16z6 die when i unplug the iac? the car fluctuates fast between idle speed of 1400-1800rpm... when i unplug the iac... its fine... idles good and smooth. plug it back in... starts freakin out again... now im not getting 14 iac code.. im getting 41 o2 heater circuit... wtf? anyone heard of an oxygen sensor cause erratic idle???
