Code 16 and Code 43
Discussion in 'HYBRID -> EG-EK / DC' started by importimage, Jun 30, 2003.
  1. importimage
    importimage Senior Member
    British Columbia, Canada
    My car runs for about 15 minutes then I get a code 16 and code 43 come up.
    I recently had my main relay re-soldered, fuel injectors cleaned and new fuel filter installed. I thought that these checks and replacements would rid of these annoying codes.
    -I am going to change my O2 Sensor.
    -I have not checked the fuel pump....but it should be good. It is a Holly.
    Does anyone else have any ideas??????
    _______
  2. darwins_vtech
    darwins_vtech Senior Member
    Wisconsin
    under the articles section there is a reading about trouble codes. look there first and then try to fix the codes!
    Darin
  3. importimage
    I am still getting a code 43 (Fuel Supply System). Could my fuel pump be screwed but the car still run???
  4. pissedoffsol
    turn the key to on, but not turn the car over. listn closely, and you should hear the pump turn on under the rear seat.
  5. importimage
    When I turn the car on Ac, I do hear the pump turn on. Does this indicate that the pump is good? I have heard some people talking about a fuse for the fuel pump. Where is this fuse??? or do they mean the main relay (Not a fuse)?
