code 17
Discussion in 'ECU's, Electronics, and Tuning' started by Quick EG, Mar 14, 2005.
  1. Quick EG
    Quick EG Junior Member
    I finished My b18 lsvtec swap and now My ecu is throwing a code 17. I replaced the Speed Sensor but I am Still getting the code. I am using the jdm y1 cable tranny. Would this be the problem. I am not using the cable speed sensor I am using the digital one. Any one have any Ideas. Thanks
  2. pissedoffsol
    a digital vss? if your talking about obd0 VS obd1/2 pulse differences, then ok, you should be good- match the vss with the ecu.
    if its not working, make sure you put it in right. theres a little pint in there that needs to be lined up properly.
  3. Quick EG
    The vss is off a 94 civic. The ecu is a p28. OBD1
    What Pin are you talking about? the one that regulates the voltage? It seem right.
    Could I have a ground problem?
