Code 22 Help Please?
rufio0306
I have a 94 EG with a 95 GSR engine swapped into it. I can get 2 good pulls past 5500 RPM, but then it goes into a limp mode and redlines at 5500 RMP. It has code 41 (o2 heater) not worried about that I am wiring in a 4 wire O2 sensor, but it also throws Code 22 (Vtec Pressure Switch) the wiring to the ECU is good and has good ground. is there a way to test the sensor with a MultiMeter?
What kind of switch is it, an open and closed, or is it a actual pressure transducer where it reads actual pressure?
here are the pages regarding troubleshooting that error
Has good oil pressure to the switch, I hook up the genesys scan tool and it reads on when plugged in and off when un plugged (which means its working). still getting the code after hitting VTEC. Any ideas? Also it Hesitates when warm. maybe related?
