Originally posted by formby@Sep 22 2005, 12:07 PM
WTF????
why do you ask a question...then you get an answer....and you ask again
[post=558639]Quoted post[/post]
Originally posted by pissedoffsol@Sep 22 2005, 12:08 PM
lol
you need to run the wire. if you have a d-series in there before, your harness doesn't have it.
its a single wire. run it from the sensor (back of block, green-ish usually) to the pinout in the ecu, which can be found in the reference section
[post=558641]Quoted post[/post]
Originally posted by pissedoffsol@Sep 22 2005, 05:32 PM
there is no d-series knock sensor
[post=558734]Quoted post[/post]
Originally posted by pissedoffsol@Sep 22 2005, 02:54 PM
are you serious? you can't snake a wire through and plug it on in the proper spots on either end?
[post=558789]Quoted post[/post]
