Code 24
Discussion in 'HYBRID -> ED-EF / DA' started by VTECPOWER, Jun 19, 2005.
  1. VTECPOWER
    VTECPOWER Senior Member
    Winchester, VA
    What is code 24 on a pw0 ecu, 1st gen b16 swap in 88 crx dx?
  2. VTECPOWER
    Winchester, VA
    The led on the ecu blinks 2 times for a decent duration of time, then 4 fast times, isnt that code 24? If so I have not found what that code means.
  3. 88bluehf
    88bluehf Senior Member
    Denton,TX
    does the car run?
  4. VTECPOWER
    Winchester, VA
    yeah, the car will start but idles rough
  5. VTECPOWER
    Winchester, VA
    Could it be code 10 and also code 14 ? The led light blinks twice so 10, which would be 20 each then 4 quick times after that.
  6. jlicrx
    jlicrx Senior Member
    Colorado Springs
    probably 10 & 14 - do you have connectors at the right location? code 10 = IAT sensor - 2 wire connector with red/yellow and green/white wires - code 14 = EACV - 2 wire connector with blue/yellow and black wires - you should have one connector on the DX that doesn't connect to anything - 2 wire with black/yellow and orange wires
  7. VTECPOWER
    Winchester, VA
    i believe that they are in the right location green plug on the 1st intake runner and the clearish one near the tb. ill check when i get home and also ill talk to peter @ rywire.
