Code 4 - Crank Pos. Sensor
Discussion in 'ECU's, Electronics, and Tuning' started by ballsweat, Jan 28, 2003.
  1. ballsweat
    ballsweat Junior Member
    Hi, I'm doing a D16z6 swap in a 5th gen HB, I got all the codes cleared except the crankshaft position sensor, or code 4. The computer is swapped to a P28, the distributor was swapped twice to correct it but noth8ing changed, I have a feeling the wiring harness is busted somewhere but I"m not sure. Does anyone have some advice for clearing this code?
  2. ballsweat
    Nobody has any idea?
    Code 4 on the CEL........ no one has ever got that?
  3. hybrid4
    hybrid4 Senior Member
    Nashville,TN
    on my 4th gen, i had to add the crank angle sensor wires to the plug at the distributor. i did the same motor swap but, dont know much about 5th gen though. just gheck to see if you have 2 blue wires at your plug. thats all i know to do, hope it helps.
