Code 41 or is it code 4 & 1
I'm getting 4 quick blinks & then 1 long blink.
Also, we took it for a test run and seems like it hit a rev limit at mid rpms.(Cant tell becuz we dont have tach hooked up yet.
Originally posted by Som1Dies2Nite+Aug 3 2005, 11:24 PM-->
TWISTEDIMAGE
@Aug 3 2005, 11:15 PM
probally because it is.
does it hit vtec?
[post=535543]Quoted post[/post]​
No it hit rev limiting at mid rpms before vtec should engage.
[post=535546]Quoted post[/post]​
By the way here are parts.
Engine: D15B2
Head: P08
IM: B7
Ecu: P28
I created my own OBD conversion harness and have a check continuity on every engine wire that I have created and verified with ecu connection.
4 quick and 1 long is code 4 and 10. if you get 1 long and 4 quick and then a long pause and then the code starts over then thats code 14
-DirtyRice-
!!!Got to my website and get my newest album free!!!
your car will usually not engage vtec with a check engine light on, thats why its bogging halfway through the rpm band...
if its 4 quick, then a pause, then 1 long, then like mentioned above its a 4 and a 10...
something is wrong with your wiring...
edit: SIG NAZI says, NO PICS FOR YOU!!!!
so what am i getting in my STd when the first flash is just one long one, then followed by 16 short consectutive flashes? a 10 and a 16?
sorry, not trying to thread jack. ;)
this is pretty much impossible, never seen anything like it
16 shorts with NO pauses??
never...
