Code 43 on B20 swap
George777
^^ Likes Bewbies
I couldn't find any other posts on a CEL Code 43, unless I wasn't looking in the right spot.
I keep getting a CEL once the car is warmed up--Code 43. I have a B20 in my EF. Fuel pump was replaced with swap (LS or CRV pump I believe). Weird thing is, once the CEL comes on, the car seems to run BETTER... More often than not, if I am not getting on it, it will pop the CEL. Hard acceleration seems to keep it off for the most part.
Should I be worried about this? Time for a new pump? Honda won't look at it and nobody else seems to know. Everyone seems to say, "Just replace the pump." If that is the case, which pump to go with becomes the question. I would replace it with the Walbro 255, but if it's nothing that drastic, then I would prefer not to. Taking the tank down to change it the first time was enough of a pain...
Thanks in advance.
Accord Civic CRV CRX Del Sol Odyssey Prelude
85-98 86-98 97-98 85-91 93-97 95-98 85-98 Oxygen Sensor "A" (Primary)
defective circuit or unplugged / defective sensor
85-89 86-87 n/a 85-87 85-91 n/a n/a Oxygen Sensor "B"
3
85-98 86-98 97-98 85-91 93-97 95-98 85-98 MAP Sensor (Manifold Absolute Pressure)
4
90-98 88-98 97-98 88-91 93-97 95-98 85-98 CKP Sensor (Crankshaft Position Sensor)
5
85-98 * 86-98 97-98 85-91 93-97 96-98 85-98 MAP Sensor (Manifold Absolute Pressure)
mechanical problem / disconnected piping
* exc 94-95
6
85-98 86-98 97-98 85-91 93-97 95-98 85-98 ECT Sensor (Engine Coolant Temperature)
7
85-98 86-98 97-98 85-91 93-97 95-98 85-98 TP Sensor (Throttle Position)
8
85-98 86-98 97-98 85-91 93-97 95-98 85-98 TDC Sensor (Top Dead Center)
9*
85-98** 86-98 97-98 85-91 93-97 95-98 85-98 CYP Sensor (Cylinder)
* not a valid code for any throttle body injection Hondas
** not a valid code for V-6 engines
10
85-98 86-98 97-98 85-91 93-97 95-98 85-98 IAT Sensor (Intake Air Temperature)
12
85-98 86-98 * n/a 85-91 * n/a 95-98 85-98 EGR Lift Sensor (Exhaust Gas Recirculation)
* not a valid code if car is not equipped with an EGR valve (some Civic models are not)
13
85-98 86-98 97-98 85-91 93-97 95-98 85-98 BARO Sensor (Atmospheric Pressure)
14
88-98 88-98 97-98 88-91 93-97 95-98 88-98 IAC Valve (Idle Air Control)
15
90-95 88-95 n/a 88-91 93-95 95 88-95 Ignition Output Signal
missing or defective ignition output signal
16
90-95 88-95 n/a 88-91 93-95 95 88-95 Fuel Injector System
defective circuit or unplugged / defective fuel injector
17
88-98 88-98 97-98 88-91 93-97 95-97 88-98 VSS (Vehicle Speed Sensor)
19
n/a 88-95 n/a 88-91 93-97 n/a n/a Automatic Transmission Lock Up Control Solenoid Valve
defective circuit or unplugged / defective solenoid valve
20
90-98 88-98 97-98 88-91 93-97 95-98 92-98 Electrical Load Detector
21*
94-98 ** 92-95 n/a n/a 93-95 n/a 93-95 VTEC Solenoid Valve
* not a valid code if car does not have a VTEC engine
** not with V-6 engine
22*
94-98 92-98 n/a n/a 93-97 98 93-98` VTEC Oil Pressure Switch
defective circuit or unplugged / defective oil pressure switch
23
98 * 96-98 n/a n/a 94-97 n/a 92-98 KS (Knock Sensor)
* not a valid code if V-6 engine
30
90-98 * n/a n/a n/a n/a 95 92-98 * Automatic Transmission Signal: "A" / SEAF / SEFA / TMA or TMB
* not a valid code for 1996
31
90-95 n/a n/a n/a n/a 95 92-95 Automatic Transmission Signal "B"
41
90-98 92-98 97-98 n/a 93-97 95-98 90-98 Primary Oxygen Sensor - Heater
circuit malfunction
43
90-95 92-95 n/a n/a 93-95 95 90-95 Fuel Supply System
defective or malfunctioning fuel supply system
45
96-98 96-98 97-98 n/a 96-97 96-98 96-98 System Too Lean or Too Rich
malfunction in the fuel monitoring systems
48
98 92-98 n/a n/a n/a n/a n/a LAF Sensor (Lean Air Fuel)
54
96 96-98 97-98 n/a 96-97 n/a n/a CKF Sensor (Crankshaft Speed Fluctuation)
58
98 * n/a n/a n/a n/a n/a n/a TDC Sensor 2 (Top Dead Center)
* with V-6 engine only
61
96-98 96-98 97-98 n/a 96-97 96-98 96-98 Oxygen Sensor, Heated - Sensor 1 (Primary)
high voltage, low voltage, or slow response
63
96-98 96-98 97-98 n/a 96-97 96-98 96-98 Oxygen Sensor, Heated - Sensor 2 (Secondary)
65
96-98 96-98 97-98 n/a 96-97 96-98 96-98 Oxygen Sensor Heater (Secondary)
malfunctioning or defective oxygen sensor heater
67
96-98 96-98 97-98 n/a 96-97 96-98 96-98 Catalyst system Efficiency Below Threshold
malfunctioning or defective catalyst system
70
96-98 96-98 97-98 n/a n/a 96-98 96-98 Automatic Transmission
malfunction with the automatic transmission controls
71
96-98 96-98 97-98 n/a 96-97 96-98 96-98 Cylinder 1 Misfire or a Random Misfire
a condition is present that is creating a cylinder misfire
72
96-98 96-98 97-98 n/a 96-97 96-98 96-98 Cylinder 2 Misfire or a Random Misfire
73
96-98 96-98 97-98 n/a 96-97 96-98 96-98 Cylinder 3 Misfire or a Random Misfire
74
96-98 96-98 97-98 n/a 96-97 96-98 96-98 Cylinder 4 Misfire or a Random Misfire
75
98 * n/a n/a n/a n/a n/a n/a Cylinder 5 Misfire or a Random Misfire
* valid code for V-6 engine only
76
98 * n/a n/a n/a n/a n/a n/a Cylinder 6 Misfire or a Random Misfire
80
96-98 96-98 n/a n/a n/a 96-98 96-98 Exhaust Gas Recirculation
insufficient flow detected
86
96-98 96-98 97-98 n/a 96-97 96-98 96-98 ECT Sensor (Engine Coolant Temperature)
circuit range / performance problem
90
97-98 96-98 n/a n/a n/a 98 97-98 Evaporative Emission Control System
leak detected in the fuel tank area
91
96-98 96-98 n/a n/a n/a 98 97-98 Fuel Tank Pressure Sensor
low input
92
96-98 96-98 97-98 n/a 96-97 96-97 96-98 Evaporative Emission Control System
I already knew what the engine code was by referring to the reference section. My question wasn't what the code was, it was what should my next action be based on the code I was throwing.
I do know how to reference material.
Code 43 is generally the Oxy sensor being lazy or dead.It's easiest to just replace it than to try and test it. When it dies, the ECU goes into default If you test it, follow the Shop manual and make sure that you use a DIGITAL MULTIMETER ONLY> Analogue ones kill sensors real quick.( I use a Fluke 23)
