tymasterflex
Member
97 Civic - Motor is a b18b1 98.
the article here says its a defective circuit or unplugged / defective sensor. the problem is when i was making the harness out of the integra and the civic harness, the integra ckf plug had two wires (white/red and purple i believe...not sure on that), while the civic plug had three wires (white/red, purple and brown...again i think). well i cut the civic plug off, and spliced the integra plug on. i attached white/red to white/red and purple to purple. with the brown one, i didnt know where it was supposed to go, so i spliced it in with the purple wire. so it went {purple and brown} connected to {purple} (on the plug side). did i do that wrong? is that why i am running the code?
DIAGRAM
PURPLE to ecu<--------------\
++++++++++++++++++++----------------- > PURPLE to plug
BROWN to ecu<--------------/++++/ -------------- >WHITE/RED to plug
WHITE/RED to ecu<----------------/
DIAGRAM
