code 8 problem
Discussion in 'Civic and del Sol - EG and EK' started by rkwoos12, Dec 19, 2008.
  1. rkwoos12
    rkwoos12 New Member
    Kentucky
    hey guys i just checked my cel and im reading code 8 tdc sensor any help on how to fix this problem?
    engine seems to run fine just a little rought start when cold so any help on how to fix this problem would be great.
  2. rkwoos12
    rkwoos12 New Member
    Kentucky
    ok so i been reading up on the tdc sensor and found out it is in the distributor and i have two distributors on is currently on the car and the other on dosent have the wire plugs on it but im thinking that the tdc sensor would stillbe good so im thinking about swapin out the sensors by cuting the the sensor out of the distirbutor that dosent have plugs and put it in my current dissy what you guys think should i do this or not?>
