xips(86CRXSI)
Ok so I swap out just about everything from the wracked 90 ef hb civic to my 89 ef hb civic, I put the engine/trans/wiring harness(complete)/ecu/fuse box/axle's/and spindles.
The motor is a b16a and the problem I have is the cyp sensor is either not working or is not wired correctly, from what I can find is that the wire's go from the connector on the distributor to c1 and c2 on the ecu plug, I think that the wires are blue/yellow and blue/green. So I found them on the distributor and the ecu and thay were spliced into by someone already so I reran the wire's and I'm still getting the code. I'm not sure if that's the right way to connect the wire's or if its a mechanical problem. If anyone can tell me what to do that would be grate. Thanks.
PS The car won't start with the key and I have no dash lights, I ran a starter switch so I could start it but it would be nice to use the key and dash lights would be nice too, If someone can give me some pointers on those two thing's that would be appreciated, thanks.
