code 9 No. 1 Cylinder Position
Discussion in 'HYBRID -> ED-EF / DA' started by monty92, Oct 14, 2009.
  1. monty92
    monty92 New Member
    regina, sask
    i have an ls/vtec b18a block p72 head and a p28 ecu. when i let the car sit and idle it sets a code for No. 1 Cylinder Position. is that normal?
  2. skellagher
    skellagher Elder Driver
    Newark, De
    sounds like the timing is off if you ask me
  3. skellagher
    Newark, De
    or a crank position sensor
  4. 97h22dxcoupe
    97h22dxcoupe senior member
    Coffeyville, ks.
    no its not normal so try doing the ckp trick on ecu harness that should fix your problem,if this helps rep me up plz...:D you should be able to find the link in the reference forums,good luck bro....
  5. D16SiHatch
    D16SiHatch New Member
    ckp trick? there is no ckp trick. it's ckf you're thinking of. seeing as how he's using a p28, which is obd1, there is no crankshaft fluctuation sensor to bypass.
  6. RoughKnight
    RoughKnight Christmas Car
    Ottawa, Ont
    you need more detail before we can try to accuratly assess the problem...
    Randy crom likes this.
  7. monty92
    monty92 New Member
    regina, sask
    what more info do you need? its the distributor off the stock b18a head. it was made to work with the car.
  8. monty92
    monty92 New Member
    regina, sask
    i have tried to back the timing off and its still setting the code at idle
  9. RoughKnight
    Ottawa, Ont
    sorry lol! i was zoned out and made a wierd post while fruedian slipping into another thought process lol. my bad, I have no experience with this build so I cant help.
    Free bump for my zonedoutness and the right answer!
  10. monty92
    monty92 New Member
    regina, sask
  11. boostin4fun
    boostin4fun Boosted ls/vtec ohh yeah!
    Omaha
    The cylinder position sensor is built into the distributor. When this sensor goes bad it starts throwing that code, you need to replace the distributor. I have seen this on many hondas, and replacing the distributor has always gotten rid of the code.
  12. monty92
    monty92 New Member
    regina, sask
    haha that was the answer i was afraid of. would it hurt to drive till i get cash together i mean im gunna park it for the winter within a month. and do u know what distributor will work or do i have to get it made again?
  13. boostin4fun
    Omaha
  14. monty92
    monty92 New Member
    regina, sask
    would it work with the p28 ecu tho? cause the guy who installed the ls/vtec just modified my stock non vtec distributor to work.
  15. boostin4fun
    Omaha
    Thats the distributor you should be using. Its ghetto to cut one of the legs off of a non vtec distributor to make it work on a vtec head. I dont recommend that.
    1 person likes this.
  16. souvimthi
    souvimthi New Member
    I accept with information:1993 Chevy Corsica...R.I.P
    1990 Plymouth Acclaim...R.I.P
    1991 Ford Mustang 4cyl...SOLD
    1993 Buick Regal ...SOLD
    1993 Taurus S.H.O...R.I.P
    1986 Olds Cutlass...R.I.P
    1991 Integra ls special...R.I.P
    1997 Integra ls auto...R.I.P
    1989 Integra ls...R.I.P
    1988 Ford Thunderbird 5.0...SOLD
    1993 240Sx ...SOLD
    1995 Civic D15b7 mini me w/ z6 head ......R.I.P
  17. souvimthi
    1993 240Sx ...SOLD
    ____________________________
    Taux pret immobilier actuel | Comparatif taux credit immo | Estimation interet taux pret immobilier
  18. monty92
    monty92 New Member
    regina, sask
    so any distributor from 92-95 will work with the set up i got? or does it have to be from that site?
  19. monty92
    monty92 New Member
    regina, sask
    does any one know a part number for an obd1 distributor that will work on a p72 head?
