I'm having an issue with my car,it revs very lazy and i have an idle issue. I have a 95 EG6 SiR 2 with TCS and ABS. Code 9 came up and have been told by many technicians to change the distributor which i have done many times and still can't get rid of the code. Does my car come with a special distributor? The TCS light is also on. I find that when i fully advance the distributor it idles fine and revs ok. I have physically checked the crank, piston and cam timing and they are correct. Can you help?
