Here is a TSB I found, I took te initiative to figure out the code,
January 18, 1999
BULLENTIN NO.
99-003
YEAR
1996
MODEL
INTEGRA/CIVIC
VIN APPLICATION
ALL
MIL On With Evaporative Emission Code P0441
SYMPTOM
The
MIL is on and DTC P0441 (code 92) is stored in the
ECM (Engine Control Module).
PROBABLE CAUSE
Charcoal from the evaporative control canister has contaminated the purge control solenoid valve and the fuel purge hose.
DIAGNOSIS
Follow the troubleshooting flowchart in the 1996 Integra Service Manual.
If the troubleshooting flowchart indicates that the evaporative purge control solenoid valve should be replaced, go to CORRECTIVE ACTION.
CORRECTIVE ACTION
Replace the evaporative control canister and the evaporative purge control solenoid valve.
PARTS INFORMATION
Evaporative control canister:
P/N 1 7300-S04-G31
WARRANTY CLAIM INFORMATION
In warranty: The normal warranty applies.
Operation number: 121149Flat rate time: 0.5 hourFailed P/N: 17300-S04-G31Defect code: 072Contention code: B03Template ID: 99-003A - LS and RSTemplate ID: 99-003B - GS-RSkill level: Repair Technician
Out of warranty: Any repair performed after warranty expiration may be eligible for goodwill consideration by the District Technical Manager or your Zone Office. You must request consideration, and get a decision, before starting work.
REPAIR PROCEDURE
1.Replace the evaporative control canister.
2.Replace the evaporative purge control solenoid valve.
3.Clear the fuel purge hose with compressed air.
4.Do the
ECM reset procedure.
5.Test-drive the vehicle under the conditions outlined in the troubleshooting flowchart, Problem Venfication to verify that it is repaired.
