codes
Ky'sCRX
i was having a code 21 and 23, the vtec wire was in the wrong spot. but before i check the codes it was acting like the fuel pump was going out, when you first turn the key you would hear it kick on, and since i fixed the vtec wire i'm not getting any codes. could that been the cause of it not starting or the fuel pump might be still going out. but after i fixed the wires i have been hearing it kick on all the for about twenty mins or so
