Civic_Tacoma
Member
I put my coilovers on my shocks, and everything looked right. i installed them, still no problem. I put the car back on the ground and the strut rod is going through the hole into the engine bay. The car is basically sitting on the springs only. I put the threaded body on the strut over the sleeve, then put teh spring on that, then the top "hat" on the spring, and then the strut top plate with the 2 bolts that go into the engine bay, and tightened eveything down. What do I need to do to fix this problem? Thanks.
