Coilover Spring Rates
Discussion in 'Wheels / Suspension / Tires / Brakes' started by EKDRIFTER, Feb 18, 2003.
  1. EKDRIFTER
    EKDRIFTER Junior Member
    Dominican Rep.
    Hey guys....
    learned my lesson; you get what you pay for....
    i have AROSPEED COILOVERS...in my 96 CIVIC HB...the ride is BOUNCY AS heck!! i currently have 400lbs springs up front and 350lbs springs at the rear
    people have reccomended me to get better spring rates...
    what do you guys recommend for a daily driver....im gonna stick with the coilovers just going to change the springs for better rates...
    forgot to add.....i got 17" konig flatlines with FALKEN 205/40/17 tires
    daily driver in a non-perfect road...
  2. CRX-YEM
    Wallingford, CT
    AROSPEED COILOVERS are most likeley crap.
    it most likely isn't the spring rate per say.
    what shocks are you using. cause it sounds more like a shock problem than springs.
  3. civicSiR1
    civicSiR1 Senior Member
    GROUND CONTROLS! by the way, get new shocks too!
  4. chris
    chris Senior Member
    nihon
    agreed, sounds like ur springs are doin all the work and ur shocks are doin anything on the rebound to help
  5. EKDRIFTER
    Dominican Rep.
    my suspension is REALLY STIFF!! i dont think its a rebound problem...it has way too much rebound....
    my car feels like if it was on a BOARD!!
    remember...400lbs spring rate up front and 350lbs down back!
    HEEEEEEEELP....gymkhana coming up soon! jeje
  6. ahedau
    ahedau Senior Member
    Middle GA
    based solely on what I've read from Honda tuning books, mags, articles...
    Try swapping the front to the rear to make it more neutral.
    But I'm confused about your problem...first you said it was "bouncy as heck" then you said it was "really stiff"
    So which is it? A bouncy ride would normally be caused by worn shocks. If they're brand new, they may be defective :( If they are used, try replacing them :)
  7. chris
    chris Senior Member
    nihon
    too much rebound...exactly, if u find that ur car is bouncing alot after a bump or uneven surface, then the shocks are not helping the rebound, ie the springs are rebounding faster than the shock can control.
    a ride can be stiff and bouncy at the same time. from the description i am guessing that the car is not settling fast enough. u need better shocks if u are using stock ones with that spring rate.
