coilover springs
Discussion in 'Wheels / Suspension / Tires / Brakes' started by rico2001, Oct 29, 2002.
  1. rico2001
    rico2001 Member
    when installing coilover springs. do you have to remove the spring perch?
  2. pissedoffsol
  3. knowledge
    knowledge Senior Member
    Beale AFB, CA
    You need to disassemble the whole strut. Remove the spring and then put the springs on. Then bolt everything back together and in the car! Just make sure you cut your bump stops in half!
  4. Liquidblaze
    Liquidblaze Senior Member
    Huntsville, AL USA
    Those yellow things, why do you have to cut them in half? I am putting new ones on today. I putting on skunk2, I have goldline on there now and they suck ass.
  5. phunky.buddha
    Dallas / Fort Worth, TX
    If you're lowered, you want to cut the bump stops so you regain some suspension travel. Civic have tons of space inside the wheel wells, and it's a shame to be bouncing off your bump stops when you still have space to compress...
  6. dohcvtec_accord
    dohcvtec_accord WRX Sellout
    The left lane
    I had to cut 3/4 of my stops to get a nice suspension travel.
  7. rico2001
    rico2001 Member
  8. phunky.buddha
    The perch? Sometimes you have to move it, sometimes you don't... it depends on the installation and what parts are provided. You'll typically need to transfer it to the new shock setup though.
  9. rico2001
    rico2001 Member
    I have kyb agx adj. ... I guess I will just see how the installation goes and if the perches need removing, then I'll remove them.
  10. phunky.buddha
    Cool. Just go for it- it's not that hard... just takes a long time.
  11. rico2001
    rico2001 Member
    is there such a thing as to cut your bumpstops to much? if so what is the limit?
  12. knowledge
    Beale AFB, CA
    I wouldn't cut them anything less than 1/4th the original! If it got any thinner than this and your shock bottomed out too hard! CRIZZZZACK! then you will crack and blow ya shock!
  13. ZC 89HATCH
    ZC 89HATCH Senior Member
    nor cal
    word i blew the hell out of my stoppers cause i blew my stock shocks at a 3 and a half in drop
  14. pissedoffsol
    standard with lower springs is to cut them in half, and use the thicker part.....
  15. Liquidblaze
    Huntsville, AL USA
    I lowered my car 3 3/4" and I blew my shocks to hell. Getting KYBs in a couple weeks, if cash flow is better, Koni Yellows.
