EGDriver93
Installed Buddy Club N+ Spec Dampers on the EG. Did not get the polyurethane upper mounts I thought I would. Should I get some Cusco's? or just use the originals on there?
THE MAIN ISSUE is one side (driver side), seems to be poking through the mount hole a little higher than the passenger side. Any reason why? Ride height is the same on both sides. This is causing it to jump inside the opening.
Any comments are welcome. Thanks guys.
