Cold Air Intake problem (Accord 1996 EX-R VTEC)
Discussion in 'Accord' started by tacosauce, Mar 1, 2010.
  1. tacosauce
    tacosauce New Member
    Hi!
    Vehicle : Honda accord 1996 EX-R (canada-only model, roughly equivalent to the US EX) 2.2L VTEC.
    I ordered a short ram cold air intake on eBay. When wanting to install it I realized that my origin air intake is plugged into a separate rigid plastic tube-like thing below, which is itself plugged into some kind of box with a butterfly valve on the entry which I think contains some sensors (a few wires are plugged on it).
    Before ordering I read some tutorials on the net about installing, and none of them seem to talk about that extra piece of hardware. Maybe it's because I have a vtec engine?
    To make things worst, if I manage to actually install the cold air intake I will have to move that box and tube elsewhere because it's in the way.
    Anyway, I was wondering if anyone knows what this box is, and if there is any way for me to actually use my new air intake.
    Here's a picture of my origin air intake with the problematic part in the red zone.
    Here's a picture of the cold air intake system I bought.
    Any help will be greatly appreciated. Thanks!
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    a real pic of the motor would help
  3. DESPAIN
    flower mound TX
    you need to take all that stuff out.....and put it in a box. none of it is needed. then hook it up and plug in the hose to your valve cover.
  4. BrutalB83
    Rochester Hills, MI
    Ah yes. I went through this on my Accord too. Unfortunately I don't remember exactly how to resolve the problem. I bought an AEM intake and it actually had instructions about how to bypass all of that...
  5. tacosauce
    So I do need to do some bypassing to make sure I don't get a check engine?
    Well, I'm glad I at least know I can remove the box.
    Thanks alot for the help guys, I really appreciate it!
  6. Cliver
    Cliver New Member
    AHAHHAHAHAHA! that blows but yes a picture of a real motor would definitly help.
  7. DESPAIN
    flower mound TX
    same thing on my prelude! i just took all that stuff out.
  8. tacosauce
    Time to install this baby!
    Thanks everyone!
  9. tsellersjr93
    tsellersjr93 CB7 with vtec gotta love
    Florence
    Sweet i wanna see a pic when your done :)
  10. double0Si
    double0Si ლ(ಠ益ಠლ) VIP
    Columbus, Ohio
    All that stuff is only there to quiet down the intake noise. I pulled all of mine out of my Civic Si as it was in the way of my Password JDM intake. Its a PITA but necessary.
  11. eg6sir
    have you actually posted anything helpful since you've been here... i think every post i've seen from you starts with AHAHAHAHAHA!
  12. double0Si
    Columbus, Ohio
    :werd: That dude is a tool.
  13. BrutalB83
    Rochester Hills, MI
    Not that I've seen...
  14. mcmurtry1986
    mcmurtry1986 New Member
    i got a question, my 94 civic ex idles up and down when cold, i replaced IAC valve but still same problem, its not a coolant issue either, i wa told to check the thermo sensor under throttle body, n e body else have n e suggestions?
  15. MichaelATN
    MichaelATN New Member
    Yeah post pics when your done =D
  16. patmccrotch
    patmccrotch New Member
    hi Thanks for your help guys.
    I had the same question.
    dunno how to post pix so Ill try it this way.
