Cold star help....help
Discussion in 'HYBRID -> ED-EF / DA' started by Oscar112709, Sep 8, 2016.
  1. Oscar112709
    Oscar112709 New Member
  2. CAFROG
    CAFROG Honda Minion VIP
    NOR-CAL
    Tell us more about the setup. I checked the link but the information given is limited.
    It's it's a B series Frankenstein automatic.
    My first thought is the fast idle Thermo valve. OBD1 needs a fast idle Thermo valve but OBD2 has such functions controlled by the ECU. So it kind of depends on the ECU and if the throttle body has a fitv. I believe its function is to help idle at cold start. Maybe you do have an fitv but it's is stuck?
    The fact that it's an automatic makes me feel like it could be something I am not knowledgeable about.
    Can you get it to run normal at a cold start if you give it some gas?
  3. Oscar112709
  4. Oscar112709
    Oh yeah is obdo automatic jdm pr3
  5. Oscar112709
    1991 acura integra automatic same harness b18a1block b16ahead obd0
  6. Oscar112709
  7. CAFROG
    NOR-CAL
    Do you have a FITV or is it a OBD2 TB? Seems most B16 heads in the states are out of a 99/00 Civic Si so that's why I ask.
  8. Oscar112709
    Yes it has one I just took it to the shop I have a spare one I gave him he said going to clean it and make sure the scew is not loose or to tight.....but he said the cold start cold be maybe fuel related
  9. CAFROG
    NOR-CAL
    Hard to believe it's the fuel pump (based on the problem being cold start only). Fuel filter is an easy change (but rarely this "miracle fix"). Injectors can be checked and cleaned for cheap. Maybe the OEM FPR is bad?
  10. Oscar112709
    I have a aftermarket one with no Gage ...but the dude adjusted to much so I'll need a tech gauge
  11. dilbeckskate
    dilbeckskate infamous
    Kennesaw Ga
    Soooo what your saying is we dont have the information here to diagnose your car... not going to be fuel pump or filter, yea id also put a stock FPR back on, 0 performance gain changing it from oem
  12. Oscar112709
    Yeah I put the stock one back in while ago...I sill don't know hoping is that stupid fitv crap
  13. Oscar112709
    Quick question is the map sensor play n play? Or is it like the tps sensor that needs a mutimeter
  14. dilbeckskate
    Kennesaw Ga
    Long as you havent messed with it shouldnt have to touch the tps, are you using all the same obd generation electronics ?
  15. CAFROG
    NOR-CAL
    Map sensor is plug and play but I think it should be for a B series VTEC that matches OBD for ECU.
  16. Oscar112709
    No .just the dizzy ecu tcm intake manifold.everything else is da Integra
  17. Oscar112709
    Gunna find one on eBay and see ....
  18. dilbeckskate
    Kennesaw Ga
    Id run everything obd0 bseries vtec
  19. Oscar112709
    Even eBay selling map sensors for b18/b16... I thinking I should be good
  20. dilbeckskate
    Kennesaw Ga
    I mean id use the obd0 bseries intake and dizzy and everything from a obd0 b16 and a b16 ecu and just get it remapped
