complete swap needed?
marek
Do i need to get the complete swap for a b16 into my 90 ls teg, or could i just get the motor, tranny, and ecu package?
You shouldn't need the complete one. The main thing the complete swap inculdes are axles, which you already have. Your stock shift linkage should work too, along with your stock mounts.
now my real question is why you would want to swap your LS for a b16. The b16 will probably be slower than the LS engine. And if your LS is blown, sounds like a good time to build an LS/VTEC.
im getting the b16a motor which is v-tec which has more horsepower than my motor that i have now , its the si motor
