vpSPOONsol
have a d15b7 and i want to know how high of a compresion ratio it can handle? does higher octane corralate with higher compresson? cause that wont be a problem over here in england. if an engine does blow due to high comp. what usually goes first? ex. gasket, valves, then pistons. i know a thicker head gasket is used to lower compression, but does that reduce horsepower also?
i plan to do a mini me with a jdm d15b head w/ aftermarket cam and internals...this is for everyday drving too, thanks
