Originally posted by B16@Oct 17 2003, 12:11 PM
check your other post, you asked the same question
you will get around 11.5:1
Not according to c-speed. The have it at ~10.8:1 in an otherwise stock B16A.
Originally posted by lsvtec@Oct 17 2003, 03:20 PM
Because the B16A/B have the same piston to deck clearance. They aren't saying the blocks are the same, just that the pistons are the same distance from the top of the block at TDC for the B16A/B.
Originally posted by sleepergtx@Oct 17 2003, 08:32 PM
Wait, my brother always told me that a 99-2000 SI B16a2 has 10.0:1 compression, now you're all saying it has a 10.8:1?
So whats the cutoff for having to use premium? my escort has a 9.0:1 and it will run fine on 87, yet a 10.0/.8:1 needs premium?
Originally posted by B16+Oct 18 2003, 04:43 AM-->sleepergtx@Oct 17 2003, 08:32 PM
you don't read very well, they are saying you will have 10.8:1 if you put CTR pistons in a B16A.
also, there is a nifty reference section that has engine specs.
https://hondaswap.com/reference/index.p...de=engine&id=15
