Compression ratio
Discussion in 'Engine Building' started by Vai, Jul 22, 2005.
  1. Vai
    Vai Junior Member
    Hy all,
    Convers with all of you on this forum is new for me, so i hope i will ask the good question.
    I just want to know the aproximate compression ratio i have with this setup:
    Stock B18C1 Bottom with type R pistons and rods
    3 mm Cometic head gasket
    and B16 Head.
    I dont have a compressiometer, but i think i'm closer to 9.5 or 9.0 to 1.
    Every answers will be appreciate.
    Thanks all. :( :)
  2. B16RacerN2NR
    B16RacerN2NR Working Hard VIP
    Moving back West...
    IMO, you are about 9.8-10.2. Just a wild guess.
  3. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Somewhere in the low 9 range, depending on if you have USDM ITR pistons, or JDM.
  4. brian11to1
    brian11to1 Senior Member
    IMO, using c-speed's site and USDM ITR pistons its at 10.1:1...
  5. xj0hnx
    C.C.TX.
    Did you adjust for the head gasket? Using theirs I got around 10.1 till I change the HG to 3mm.
  6. Vai
    Vai Junior Member
    The pistons is USDM. what year is, i don't know.
    Sure that, in N/A i will be closer to 10:1 (maybe a little bit more).
    But, i want to run force induction, that's why i swapped the head (B16A: bigger combustion chamber) and put a 3 mm cometic headgasket.
    I think i will try to buy a compressiometer and do the test myself.
    Maybe it's the best way to go.
    Thanks everybody FOR YOUR HELP. :) :)
