Compression test
Carnage
Just finished checking my compression on my d16z6 in my 90 hb
1st- 155psi
2nd-150psi
3rd-130psi
4th-145psi
I did this because i notice is starting to burn some oil.
its not burning any antifreeze tho
could this be the botom end or in the head ???
should i keep driving my car like this ????
You're probably losing seal on the rings in your 3rd cylinder... add a few drops of oil through the spark plug hole, then run your compression test again. If #3 comes up in line with the other 3 cylinder, it's probably your rings.
A leakdown test will definitely tell you more about what's going on, but a standard compression test is always the first step.
