Compression
Discussion in 'General Tech and Maintenance' started by Slow&Delirious, Mar 18, 2009.
  1. Slow&Delirious
    Slow&Delirious isn't fast or furious
    Boonville NC
    So i ran a compression test on the sol today, im not exactly surprised with the results but here they are (D15B w/ 217xxx miles)
    cyl 1 - 145 psi
    cyl 2 - 175 psi
    cyl 3 - 130 psi
    cyl 4 - 178 psi
    i havent bothered looking for a spec, but i have a fairly noisy valvetrain but i adjusted it to spec by the book and then I took it to have it adjusted after it not getting any better, and the timing is set correctly, any thoughts?
  2. MthaFuknGreen
    Lodi, CA
    you have bad compression in cylinders number one and three.
    lol
    i believe spec is like 180.
  3. Slow&Delirious
    Boonville NC
    well the engine has 217xxx miles so i assumed the comp would be low, but the general spec is about 10psi variance. I really dont want to go into the head and get new valves / springs.
    but there is no loss in power, the valves are just really loud.
  4. MthaFuknGreen
    Lodi, CA
    my car has 208xxx on it and my compression is no where near that bad..
    it has like 180,180,175,180.
    and i have frm sleeves, which are suppose to eat the shit out of rings.
    you may have a problem..
    i think your valves might be fucked up.
  5. brian11to1
    brian11to1 Senior Member
    Do a leak down test and that will help determine if its rings or valves.
  6. Slow&Delirious
    Boonville NC
    CLT is next
    soon as i can get some time. My rings are fine, if there is a problem its going to be a valve issue, and since adjustment is in spec im assuming its bent/chipped/cracked/seats/ect
  7. MthaFuknGreen
    Lodi, CA
    word.
    your valves might be worn to shit which would make the margin hella thin which would result in the valves not seating well which would probably result in the loss of compression.
  8. je power
    je power New Member
    my house
    damn dude time for a b series lol
  9. Z6CRX
    Z6CRX übber ɐɾuıu etarip
    Pittsburgh, PA
    seafoam tiem! Helped clean up carbon on a sticking valve on my H22 once.
  10. MthaFuknGreen
    Lodi, CA
    might as well just pull em all out and put em to a buffing wheel.
  11. 97hatch
    97hatch ?
    Anderson IN
    get a y7 head and wake that 1.5 up it sure did mine. You are probaly correct about the valve issue my sol had almost no compression on number 3 for a chipped valve so i replaced the whole head with a y7 head and it made a huge improvement in the way it performed but be ware. doing this head sway rais compression to 10-10.5 depending on the gasket you use
