i just always heard that lower compression was used for fi. being the assuming person i am, i thought it was to save the engine. if you use 11:1 compression w/ a turbo id assume itd be easier to throw a rod or the like...gotta think...you are putting a lot more pressure on that engine than what it was designed for....
people turbo stock gsr's,b16's and type r's all the time. you just dont want to turbo a 13:1 cr. in other words if your building a turbo motor dont throw high comp pistons in. run lower compression and more boost
