Computer Questions from my 95 lude swap
Discussion in 'ECU's, Electronics, and Tuning' started by beano135, Aug 25, 2008.
  1. beano135
    beano135 New Member
    I swapped a F22b DOHC engine into '95 h23a1 prelude w/auto trans.
    I was told this should work alright but I am having some running issues.
    I'm wondering how the computers work, the engine came from a 92 manual car now its in a car with a auto computer. I was wondering if this computer/cams don't like each other. Can I take the chip from the 92 manual and put it into my 95 auto or does the chip inside the ecu control the automatic's shift point and torque converter lockup. I don't know how the honda ecu's work internally that well yet. Any help appreciated!
  2. t3t4delsol
    t3t4delsol New Member
    York, Pa
    you need a 5 speed ecu, also stock chips are sodder into place, 5 speed and auto ecus guts are different.
  3. beano135
    beano135 New Member
    so the computer is different. is the chip different too. i've seen aftermarket chips so I assume they are changeable.
    my problem is fixed. the timing was actually off so after the engine was timed properly it runs great.
  4. t3t4delsol
    York, Pa
    well glad to hear the problems fixed, sorry I misread your first post, I thought you swaped the manual tranny with the motor. stay away from aftermarket chips they mess shit up. manual and auto ecus have some different peices on the inside of them. also was your h23a1 vtec or not?
    [edit] H23A1
    The H23A1 was an increased-stroke, non-VTEC version of the H22a, designed for the North American and UK market 1992–1996 Honda Prelude Si. It shared the same Fiber Reinforced Metal (FRM) cylinder wall liners with the H22a.
    Specifications
    • Bore x Stroke: 87.0 x 95.0 mm (3.74 in)
    • Displacement: 2258 cc (138 cu. in.)
    • Valve Configuration: DOHC, 16 valves
    • Type: In-line 4 cylinder, aluminum block and head
    • Compression ratio: 9.8:1
    • Max power: 160 hp (119 kW)
    • Max torque: 163ft·lbf (207 Nm)
    • Redline: 6500 rpm
    • Engine Control System: Honda Systems PGM-FI with port fuel injection
    • Valve Gear: belt-driven dual overhead cams, 4 valves per cylinder
    There is also a DOHC VTEC version of the H23A, available in the CH6 and CL2(4WD) accord (CF4 wagon) SiR in the European Markets.
    Specs remain largely similar to the H23A for North America, albeit differ in the introduction of VTEC mechanism and more power
    Specifications
    • Compression ratio: 10.6:1
    • Max output : 200 PS (197 hp/147 kW) @ 6800 rpm
    • Max torque : 220 N·m (160 ft·lbf) @ 5300 rpm
    • Redline: 7200 rpm
    • [edit] F22B
      This engine was used in the 1992-1996 Honda Prelude Si in Japan. It is similar to the H23A,.
      Specifications
      • 2.2L
      • Bore × Stroke: 85.0 × 95.0 mm
      • Displacement: 2156 cc
      • Compression ratio: 9.3:1
      • Max power: 166 hp (119 kW) @ 6000 rpm
      • Max torque: 150 ft·lbf (200 N m) @ 5000 rpm
  5. t3t4delsol
    York, Pa
    [edit] H23A1
    Specifications
    • Redline: 6500 rpm
    Specifications
    • Redline: 7200 rpm
    • [edit] F22B
      Specifications
      • 2.2L
