Coneverting a DA automatic to a 5 speed Manual
Discussion in 'HYBRID -> ED-EF / DA' started by Jdubspeeds, Aug 4, 2005.
  1. Jdubspeeds
    Jdubspeeds Senior Member
    Tacoma Wa
    Has anyone done this swap, what all do you need??
  2. reckedracing
    reckedracing TTIWWOP VIP
    NY
    its kind of self explanatory...
    cable tranny, flywheel, clutch, throw out bearing, pressure plate, 5 speed brake pedal, 5 speed clutch pedal and pedal assembly, clutch cable, possibly diffrent mount for the tranny, shifter, shifter rods, and possibly an ecu...
    oh and possibly axles...
  3. brian11to1
    brian11to1 Senior Member
    cable trans
    5 speed pedal assembly
    clutch kit
    shifter/shift boot/knob
    shift linkages
    ECU (unless you want to convert the auto to a manual)
    youve got to drill a hole in the firewall for the clutch cable
    you've got to shim the passenger mount like a lot.
    i used the auto axles and intermediate shaft
    there's other small shit, you may want to get the rear mount as well, fornt mount for a manual. you'll def. need the passenger side manual trans bracket and mount.
    to avoid shimming the passenger side mount, you can drill the spot welds on of the AT mount out so the AT frame mount cames off and weld the MT frame mount to the chassis.
  4. Boondock Saint DX
    Boondock Saint DX Senior Member
    Des Moines, Iowa
  5. brian11to1
    it cost me about $400 for used parts and $435 for cluch/flywheel... so about a grand.
  6. DirtyRice
    DirtyRice Junior Member
    if place racing is still in biz then they carry a auto to stick mount conversion. if they are no longer try hasport.com. i did an auto to stick in both of my da 4dr's and it was easy except drilling a hole in the firewall for the clutch cable and puting in 5spd pedals. that was a bitch!
    -DirtyRice-
    !!!Got to my website and get my newest album free!!!
    [​IMG] [​IMG]
  7. brian11to1
    why did you post pictures of a car that has nothing to do with this thread?
    intsalling the pedals and the hole for the cable are not hard at all.
