civic92jak
Ok guys, this is my ordeal and will try to explain the best i can.
JDM OBD1 DOHC ZC Motor
Stock P06 ecu
My motor is running fine but suddenly throws codes 8 and 9, these which are bad TDC and CYP Sensors. So i dismantle the Distributor and replace all parts from another Distributor that i have. Everything went in smoothly and buttoned it all back up. No more codes, but not running. I have plenty of spark. Not exactly sure on the timing, but nothing was messed with other than removing the distributor. I turn it over, nothing but a "capoot" like the timing is off. So i came up with maybe i had gotten the gear on the engine side of the distributor on wrong and it was 180 off. So i pull the dizzy and turn the gear 180. Bolt it all back up, nothing. Not even a "capoot". Change everything back and still getting the "capoot", but won't actually start. So i take and adjust the distributor little by little. Still nothing. I've since called it a night at 4:15am this saturday morning. If anyone has any insight on this would be helpfull.
Stock P06 ecu
