controlling 450cc injectors on n/a built h22a
Discussion in 'ECU's, Electronics, and Tuning' started by alterdcreations, Jul 30, 2006.
do you think this will be a success
Poll closed Aug 29, 2006.
  1. yes and why
    0 vote(s)
    0.0%
  2. no and why
    0 vote(s)
    0.0%
Multiple votes are allowed.
  1. alterdcreations
    alterdcreations Member
    Gettin lost in N.Y.
    im currently intrested in controlling 450cc injectors with a vtec afc.
    im currently in the process of building and developing a n/a build for a h22a
    it will use stock usdm pistons (fully rebuilt with apr rod bolts and coated main & rod bearings). the motor will spin to 8600 rpm max.
    also i will be using a alterdcreations stage 2 ported head/ custom factory intake manifold work, and a 74mm throttle body. i will be using stock valve train(to compare a stock p13 cylinder head against my stage 2 head for hp referance).
    i know that the motor will max out the factory h22a injectors.
    will a vtec afc be able to control 450cc dsm injectors for my n/a build.
    in the future i will run crower (custom combo of stage 3 specs with more lift and the same duration)or skunk 2 camshafts. i will be using the stock valves.
    i also using a chiped poa ecu (ericks racing reprogram)
    at first this will be a cost conservative build with stock parts to get a referance for future upgrades. does the vtec afc have the capabilty to handle the first part of this engine capabilty test?
    also i will us dc 2 1/2 inch header , cat less exgaust / in future it will be a prospeed and2 1/2 in taper into a 3" exgaust.
    any ideas on fueling my first stage set up?
    thanks
  2. reikoshea
    Dallas, TX
    yes it will control those injectors. i would only use the VAFC as a place holder though...get an obd1 P72 or P28 and get a real program for the engine instead of using an AFC Hack.
  3. alterdcreations
    Gettin lost in N.Y.
    i was going to use a chipped poa ecu instead
  4. alterdcreations
    Gettin lost in N.Y.
    do you think a chipped poa is as good or the same as a chipped p28 or p13.?
  5. reikoshea
    Dallas, TX
    ive never heard of anyone using the accord ecu, and i neither hondata nor crome (the two most widely used tuning software) support the P0A.
    Id look into picking up a p28.
  6. alterdcreations
    Gettin lost in N.Y.
    Thanks I Will Look Into That
