conversion
elpayaso201
ok i want to do a conversion from rear drum breaks to disk bracks from a 90 to a 92 civic hb what do i need????
:ph34r:
so you are taking the discs off a 90 and putting them on a 92??
Take the trailing arm off the 90 (leave all the other arms) also use the runner brake lines for disc from the 90 car, and the e-brake cables from the 90 car. The 3 other arms (lowr, upper and front) may be different so keep them on the 92.
