Converting from obd2 to obd1 injector plugs
Discussion in 'ECU's, Electronics, and Tuning' started by boostin4fun, Nov 11, 2006.
  1. boostin4fun
    boostin4fun Boosted ls/vtec ohh yeah!
    Omaha
    Hi, im in the process of converting my 2000 civic over to obd1 plugs so i can use my rc injectors. I was wondering if this was as easy as hooking up the stripped wires together and the solid wires together, or is this backwards? When i look at the two different plugs from the front, side by side i see that the solid and stripped wires are on different sides. Any help would be appreciated. Thanks.:(
  2. D See 2
    D See 2 Senior Member
    Baltimore, MD
    Yea, just wire the striped wires together and the other colored ones together... From right to left (#1 cyl to #4 cyl), the colors go brown, red, blue, yellow.
  3. boostin4fun
    Omaha
    Thanks for taking the time to answer my question, it is much appreciated!!
