converting obd0 crx to a obd1
Discussion in 'General Tech and Maintenance' started by Travisl, Jul 9, 2008.
  1. Travisl
    Travisl New Member
    wichita,ks
    i have most the harnness hocked up but im missing three plugs the o2 sensor the throtle body sensor and the water temp plug i have them on the obd1 harrnness but if i hook them up i dont know were they go can some one help me im getting to frustated and no web site is telling me wat to do:hide: im putting in a sohc zc vtec in my car if that helps
  2. boostin4fun
    boostin4fun Boosted ls/vtec ohh yeah!
    Omaha
    You probably would be better off getting a dx harness that hasnt been all hacked up. Then go to www.rywire.com and buy the obd0-obd1 conversion harness. Follow the instructions that come with the harness. It will have leads for the four wire o2 and vtec, you will just have to run the wires and rob a few plugs off a donor harness. If your car is the dpfi you will have to do the mpfi conversion first. You can search and find good write ups on that.
  3. Travisl
    Travisl New Member
    wichita,ks
    i have a mpfi harness
  4. boostin4fun
    Omaha
    Did you find a mpfi harness, or did the car originally come with one? If the car was not originally mpfi you cannot just simply replace the harness with a mpfi one it wont work. If that is the case you need to find another dx harness and do the conversion.
  5. Travisl
    Travisl New Member
    wichita,ks
    the harness i am useing for the swap i mpfi i have a stock dx but its an obd0 harness
  6. 90_EF_Hatch
    90_EF_Hatch Señor Member
    Dallas Texas
    your going to have to do the obd0-obd1 conversion on your harness, and get and obd0-obd1 ecu jumper. and a vtec subharness.
    also you will need the 0bd1 ecu, (im assuming you meant the d16z6 not the sohc zc, because im 90% sure the ZC's are not vtec), which would be the p28
