converting to obd1 help please!!!
93hatchbak
so i bought a b16a swap out of a crx and need to convert it to obd1. i know i need to change the dizzy and the injectors. wat else will i need? do i need a different engine harness? does someboday have a list with the parts and want to share that with me?
thanks
Yes your stock engine harness is what you're supposed to use.
you won't need the injector resistor box because you said you will be using obd1 injectors.
