Coolant backfired!!!
Discussion in 'General Tech and Maintenance' started by Arrogant_, Jun 14, 2005.
  1. Arrogant_
    Arrogant_ Member
    My buddies and I did a swap for my LS. We replaced the headgasket and thermostat, and waterpump. Unfortunately, after five minutes of driving the engine got extremely HOT and the coolant flowed back to the radiator, and the temp. in the cluster showed the needle up all the way to "HOT".
    One of my buddies said it might be the headgasket. We checked and the headgasket is jerked a little.
    Any opinions?
    Thanks....!!!!
  2. pissedoffsol
    sounds likely.
    get another one (not worth the labro to NOT replace it for 60 bucks) and make sure its seated correctly. one side goes up. one side goes down. it can't be flopped.
    then, make sure you bleed out the coolant system. air packets will cause overheating.
