serrilion
In my own little world!
So I have a 93 prelude with H22a1...
We have all the coolant lines hooked up in the car, no leaks any wear in the motor. I'm having an issue with air in the coolant lines somewere!
We at 1st had the over flow bottle line from the rad hooked up, we would open the bleeder valve and then air would start flowing into the overflow bottle
So we sealled off the over flow bottles passage way. Now if I open the bleeder valve all I get is white foamish looking coolant, its consistant and does not go away even after 3-5mins of idel
Thus said any ideas? I can't leave the prelude ideling for more than 10-15mins from a cold start up as it almost pegs the thermo....
other issues is this is causing the car to be extreamly boggy after 5mins of driving...
