Coolant Leaking
importimage
I have coolant leaking from somewhere in the backside of my B20 Vtec setup and cannot locate where it is? I feel so stupid....but does anyone have any suggestions. It is not leaking from the bottom of the rad or upper rad hose.
you'd better hope you torqued the head bolts to spec...
it could be a number of things. to avoid a guessing game. pull of the intake manifold and it should be very apparent where the leak is coming from.
So, if I pull the intake manifold off....and see coolant coming out of there......then what... Should I take the cams out and check the torque on the head bolts? I have reason to believe that my water pump is screwed because of the coolant leaks on that side of the motor.
