cooling fan not working
Discussion in 'HYBRID -> ED-EF / DA' started by Taco15, Jul 3, 2005.
  1. Taco15
    Tallahassee Fl
    its me again :D hey i was told there is switch for the cooling fan located behind my ls block. (88 crx with lsvtec). I know the fan works but why wont it turn on? The car doesnt overheat but i would like them to come on since the weather and humidity is horrible in FL. I checked the fuses,checked the wires. There is no power coming from 2 wires that seperate from the harness into the fan on the passenger side right beside my Intake filter. Do they come from the ecu,fuse box ? i have no idea :blink: . any suggestions would be greatly appreciated.
    ------Taco
  2. Dark91zc
    Dark91zc Senior Member
    Corona,CA
    are you obd-0 or obd-1???
  3. Taco15
    Tallahassee Fl
    obd0
  4. Estorvito
    Estorvito Soy Boricua
    Orlando FL
    Have you checked the E.C temp. switch?
  5. Dark91zc
    Corona,CA
    ok check your ecu for B4 Yellow/Green Radiator Fan Relay that is what goes into the temp switch on the back of the block then it goes to the green plug at the bottom of your radi fan (tell me the color of the wires :) )
  6. B16CRX
    B16CRX Senior Member
    Greenville, SC
    The thermo switch is located where the lower radiator hose goes into the back. you should see a plug going into it.
  7. Taco15
    Tallahassee Fl
    THAnks guyz! I just got back from an important lunch with my folks. Me and my girl are FINALLY MOVING OUT! Anyway thanks for the info. i will check all that tomm morning. HONDASWAP ROCKS!
    ---- THE TACO MAN
  8. Dark91zc
    Corona,CA
    we are here to help :)
  9. Taco15
    Tallahassee Fl
    im starting from there. its cut so i have to extend the wire. thanks guys i'll let you know what happens. :)
    i think it was just never hooked up. I found the same color wire in the harness so i hooked it up. Im waiting for the car to get to operating temp to see if it turns on.
  10. Taco15
    Tallahassee Fl
    well they still wont cut on. I followed the harness wire to the back of the block. Its seems to be hooked up. the fan is hooked up (from the green plug to 2 wiresto the harness. i believe they are a black/mix and blue/mix. where is the relay? if there is one.
  11. Dark91zc
    Corona,CA
    i will check it out on my car for you and get back to you :)
  12. Taco15
    Tallahassee Fl
    thanks man this really sucks the wires are black/yellow(maybe white due to dirt) AND solid blue with greenish spots.
    would there be a ground wire from the ecu that needs to be hooked up something? thewre a couple wires that are not hooked up. I havent had time to look at the pin#'s and tell what they are.
  13. Taco15
    Tallahassee Fl
    alright i got my lazy ass up. these are the things i found cut
    - c9(PA sensor)
    - B2 (Tandem Valve control solenoid valve)
    - A6 (purge cut-off sloenoid valve)
    WHAT ARE THESE AND DO THEY NEED TO BE HOOKED UP! I dont know much but they sound pretty damn important to be cutoff
  14. Taco15
    Tallahassee Fl
    c'mon guys i need help!
  15. B16CRX
    Greenville, SC
    I'm not sure what those are, but wire them up and see what happens. :)
  16. Taco15
    Tallahassee Fl
    nothing happens. weird. and still no fans. DAMNIT
  17. jlicrx
    jlicrx Senior Member
    Colorado Springs
    which engine harness are you using?
  18. Taco15
    Tallahassee Fl
    using the stock obd0 with a pw0 ecu. I dont know what those wires did but was able to find there match on the harness. even still i felt no difference.
  19. ripperbone
    ripperbone angry bear
    Oklahoma
    I just looked at my crx
    there are two wires at the back of the block one is yellow with a blue/green stripe and the other is a black wire. I ran those wire to the ect switch
    [​IMG].
    not sure if that helps but look on your wiring and find those two wires and hook them together and see if the fan turns on constant. if so then run the wires to your ect switch
  20. Taco15
    Tallahassee Fl
    thanks man i'll check that out asap. I might not have time since im packing for out of town but hopefully i'll get it running right. Thanks guys for you inputs
