need some help with my cooling fan...my original cooling fan froze on me and fried up the fan and fan wiring all the way through the harness back to the firewall...it also caused a short to the 15 amp cooling fan fuse under the dash and the 30 amp passive fuse on the positive terminal and the wires on the back of the temperature sensor behind the block keep frying up after i change them out...i got a new cooling fan and hardwired it to come on manually but would like to fix it to come back on normal...when i place a new cooling fan fuse under the dash and put a new fuse on the passive terminal and connect the fan it's just normal warming up...as soon as the temperature switch sensor turns on to signal my cooling fan to turn on it automatically burns the two wires on the temperature switch sensor behind the block and burns out the same two fuses...i need to know where to bypass the fan wires through the harness and where they both go to so that it could turn back on automatically...the original fan wiring is shorted out completely...the car is a 91 civic lx (5 speed)...!!!
