EF9_Hatch
Yeah
Ok, so i finally got my car fixed after not having it for a week. We replaced the water pump and so on. Tried to start and it wont, battery is good starter is brand new. all the connections are good to the starter. We were messing with the grounds from the battery and the one from the frame to the block and a couple times it fired right up without any problems, but as soon as i shut it off it wouldnt fire up. This has been an ongoing problem but usually it starts after the 3rd or 4th try. it would just click as it was trying to start but wouldnt do anything with each turn of the key. im not really sure what the problem could be. Could it be that the grounds are bad? the wires are pretty corroded and im replacing those today to see if that helps. Also the ground for the starter doesnt fit on there very securley, but it stays on, could that be the problem? I think im going to get a new battery just in case to see if that helps if i cant figure anything else out. But i figured i would ask around first before i spent the money on something i dont really need.
Next problem, My right rear tire locks up sometimes but only when i go in reverse. Brake fluid is good and the lines arent leaking on to the pads. I think its getting hung up somewhere im just not sure. My E-brake light stays on all the time even when the brake is off. But it only locks up every once in a while. any ideas? any and all help is greatly appreciated!!!
