CP-Carrillo Pistons
Discussion in 'CorSport' started by CorSport, Aug 5, 2010.
  1. CorSport
    CorSport Member
    Corsport is now offering CP pistons for a variety of applications. We’re currently still adding parts, but Corsport will sell the ENTIRE line of CP pistons (Not just K-series). Keep an eye out on the website, more applications will be added daily!
    If you don't see what you need, hit us up with a part number and we can get it for you.
    Link To All CP-Carrillo Products
    Shipping is always included in the price you see inside the 48 lower United States.
  2. CorSport
    CorSport Member
    Take it to the next level!
  3. CorSport
    CorSport Member
    Find the Carrillo Pistons you want at CorSport.
  4. CorSport
    CorSport Member
  5. CorSport
    CorSport Member
    Carrillo Pistons available at CorSport.
  6. CorSport
    CorSport Member
  7. CorSport
    CorSport Member
  8. CorSport
    CorSport Member
  9. CorSport
    CorSport Member
    Honda/Acura B-Series CP Pistons
    [​IMG][​IMG][​IMG]
    Click here to see this product in our catalog and check out the most current pricing.
    **If these are not in stock CP pistons take 2-3 weeks after the order is placed to receive and ship out**
    CP-Carrillo offers over 500 shelf parts from the Sport Compact shelf line with a wide range of sizes for the most popular engine types. Every piston and rod is designed through extensive research and development with the support of some of the biggest names in motorsports.
    CP pistons are designed for oversized valves, high lift camshafts and available in a variety of compression ratios and bore sizes. Carrillo rods are a great compliment to the assembly and are available in PRO H, Pro A or Pro SA beams. All of our products represent the highest quality and are engineered for maximum power.
    HONDA X-STYLE PISTON
    Features
    9.0-12.5 Compression Ratio
    Deep valve relief depth accommodates high lift camshaft Made for +1mm valve sizes Custom skirt cam and barrel design Accumulator grooves
    High strength aluminum forgings High performance rings Fully CNC machined and balanced to +/- 1 gram Wrist pins included at no additional cost Double pin oilers, force fed oil ring Pick lock grooves for easy lock removal Pin fitting included
    If you have any questions you can reply to this thread, send us a pm or use the contact us page on our website.
    Thanks for the continued support,
    CorSport USA.
