Cr-vtec na
Discussion in 'Engine Building' started by SpoonMotorSports, Oct 2, 2010.
  1. SpoonMotorSports
    SpoonMotorSports New Member
    peshawar Pakistan
    Hey all
    my frnd has a b20 vtec
    NA the mods are as follows
    b20b block
    b16a head
    obd1 wiring
    obd1 dizzy
    obd1 chipped ecu/8k revv
    ITR manifold
    itr cams
    rage racing cam gears
    MSD 6a with blaster coil
    RAGE RACING cam gears
    its in ef9 hatch
    any tips on tuning the ignition timing and cam gear adjustments?
  2. SpoonMotorSports
    peshawar Pakistan
    bump
  3. civicious
    civicious FüK-VTEC VIP
    Houston, TX
  4. taino0330
    taino0330 New Member
    Hey guys need tips/help on how to install the vtec on a 96 honda civic engine d16?
  5. civicious
    Houston, TX
  6. egb19c
    egb19c New Member
  7. intenseneal
    intenseneal New Member
    I run the S100 on my 98 Ls soon to be Ls Vtec. I like the S100 cheaper and works great for a DD.
  8. intenseneal
    You will need a Vtec head best choice for a 96 is the D16Y8 head but the D16Z6 will work also, Z6 is also a little better. The Intake manifold for the head you are using the ECU from a 96-98 Ex, head gasket kit for the head you are ussing. Look up mini me swap of a full write up.
  9. civicious
    Houston, TX
    You work great for being a fucking retard.
  10. brian11to1
    brian11to1 Senior Member
    Anyone else notice there are two different conversations in this thread?
  11. intenseneal
    FUCK YOU! I was only giving my opinion. S100 is great for a DD and half the cost and can be tuned on a S300 and flashed to the S100. Why would you need all the extra stuff on the S300 for a NA DD car. Jack ass.
  12. brian11to1
    S300 offers real time tuning. I prefer that, which is why I'm using it. not to mention my tunerview RD1 is supported on s300.
