Okay so I have a crack in my tranny case right around the 32mm seal bolt[dont ask other than I'm a fucking moron who has/had a crappy 1/2 tq wrench] and I'm wondering if I can have it welded.I need to know if that area of the case with the internals in can take the heat from a weld or 700F for HTS-2000
http://newtechnologyproducts.net/aluminum_repair.htm
The HTS-2000 sounds great but will I fry anything if I use it or have someone weld it,I could go buy a pound of heatsink clay but I'm not a welder and know very little about it other than a tig could be bad with the internals still in the case.I'm not sure of my ability to take the internals out and put them in a new case myself and I cant afford to have someone else transfer them right now as I've searched and heard that is expensive.
If it cant be welded has anybody had any luck with JBweld type stuff and if so what is best cause I was also looking at Permatex® Hi-Temp Aluminum Repair Compound and that seems better than JB.Thanks all.
