Crank Angle sensor
Discussion in 'General Tech and Maintenance' started by C-Bye, Oct 3, 2005.
  1. C-Bye
    C-Bye Member
    Minnesota
    I have two wires left to hookup. C1 and C2 on obd0 clips, My info says Crank angle sensor, where located on the motor? B16a motor XSi, ys1 tanny
  2. spoonfedcrx
    spoonfedcrx Junior Member
    inside distributor
  3. B16RacerN2NR
    B16RacerN2NR Working Hard VIP
    Moving back West...
    you have to wire c1 and c2 to the correct distributor pins. you have to use the big round white plug off the harness that came with your B16 because the DX distributor only holds 6 pins and also it won't plug into your B16 distributor.
  4. C-Bye
    C-Bye Member
    Minnesota
    It is a grey plug, obd1. I have them hooked up to blue wires.
    I am getting two codes #4-ckp and #9-cyp.
    anyone know the wires for these sensors, where they hookup, what color, anything?
  5. B16RacerN2NR
    Moving back West...
    is your car also obd-1 or are you trying to do a conversion to obd-1? because obd-1 doesn't use a C plug, the computer plugs are A, B, and D.
  6. C-Bye
    C-Bye Member
    Minnesota
    OMG, really! I didn't know that I was wondering what D was for. I have a obd0-obd1 jumper.
    "CKP" wires c1 and c2 go to -dizzy- what colors(grey plugs)
    "CYP" wires b11 and b12 go to-?- colors?
  7. D See 2
    D See 2 Senior Member
    Baltimore, MD
    B10 is Solid Orange
    B12 is Solid White
    They both go to the dizzy.
    C1 is Blue/Green
    C2 is Blue/Yellow
    They go to the dizzy as well.
  8. C-Bye
    C-Bye Member
    Minnesota
    Hey thanx, I thought I had it hooked up, the person who had it before destroyed the harness, I have been picken up the mess, it has been frustrating at times, I think it would have been easier to make my own harness.
