d2000honda
I have a 96 prelude with h23a1 obd2. the Crank position sensor is located with the oil pump........The h22 doesn't have this. Where can I run this sensors too.... I hears to use the h22 distributor with the Internal coil and then cut the crankshaft sensors then extend the wired to the distributor....is this correct. and where exactly do they go connecte...(what wires in distributor)
My client is getting up set and this swap is pissing me off.....Please help...
