Crank pulley
MRG719
Any one have a problem with the crank pulley spinning. The outter part is spinning on the inner part timing marks are in a different spot every time
the pulley is a two part item, an inner cup with an outer ring laminated onto it by some rubber similar to a motor mount. that's what does the dampening, however with age, it decomposes. get a new crank pulley. and by new i mean new to you (junk yard, ebay, craigslist, etc.)
Yeah they are around 250-300 new was thinking the jdm pulley. I dont have ac or ps just wonder if the timing marks are in the same place
